SONOFF ZBM5 SwitchMan Zigbee Smart Wall Switch Supports No Neutral and Neutral Wire Detach Relay Mode Works with Home Assistant
Supports both No Neutraland Neutral Wire SONOFF SwitchMan Zigbee smart Wall Switch
Note: The supported SONOFF Zigbee Hub is needed.
【Support Both No Neutral & With Neutral Wire】The ZBM5 is designed to adapt to your home’s wiring configuration. Whether or not a neutral wire is available, it can be easily connected and used. 【Compatible with Multiple Zigbee Hubs】 ZBM5 integrates with Zigbee hubs, such as SONOFF NSPanel Pro, SONOFF iHost, SONOFF ZB Bridge-P, SONOFF ZB Bridge-U, ZBDongle-E/P. 【Works with Home Assistant】ZBM5 seamlessly integrates with third-party open-source platforms, such as Home Assistant( Zigbee Dongle is required, e.g. SONOFF ZBDongle-P/ ZBDongle-E), making it perfect for your home automation needs. 【Detach Relay Mode】With the detach relay enabled, smart lights won’t lose power when the wall switch is turned off, allowing them to remain smart at all times. *Supports connecting smart lights only in the neutral required mode. 【Fully Functional】ZBM5 has all the most basic functions, like remote APP control, voice control, timing schedule, smart scene, etc, making your life more convenient.
Directly compatible withthe Majority Wiring
The ZBM5 is designed to adapt to your home's wiring configuration.Whether or not a neutral wire is availableit can be easily connected and used.
Put Smart Home Control in Your Hands
You can view the switch status anytime in the eWeLink app or remotely control the switches, managing your home's switches from your phone
Schedule Lights Off for a Healthier Routine
Set a timer in the app to turn off the lights automatically in the livingroom and bedroom late at night, ensuring a peaceful sleep.
Smart Scenes for a Convenient Life
Zigbee Two-Way Control Set up smart scenes with the Zigbee wireless button to control the bedroom light together.
Automation Work with the Zigbee sensor to automaticallyturn lights on or off for you.
Detach Relay For Wiring Smart Bulb
With the detach relay enabled, smart lights won't lose power when the wall switch is turned off, allowing them to remain smart at all times.
Effortless Control withYour Voice
You can control the switch when you're busy with a simple voice command.
A Piece of open-Source Platform Solution
Easily integrate your device into open-source platforms via Zigbee2MQTT or ZHA, creating a smart home solution that works seamlessly with devices from various manufacturers.
Works with Apple Home Via Matter Bridge
All solutions integrate SONOFF zigbee devices into your Apple ecosystm via Matter Bridge, enabling seamless interconnected device control.
