SONOFF ZBMINIR2 Zigbee Smart Switch Detach Relay Mode External Switch Control Works with eWeLink Zigbee Gateway Required 1-4PCS
SONOFF ZBMINIR2 is an extremely compact Zigbee 3.0 smart switch, capable of being installed in EU-type/86 type/120 type mounting box and supporting a maximum load of 10A, compatible with various external switch types, upgrading your traditional external switch into a smart one, seamlessly integrating smart technology into your home for enhanced convenience and control.
SONOFF ZBMINIR2 needs to be used with a Zigbee hub, such as SONOFF NSPanel Pro, SONOFF iHost, SONOFF ZB Bridge/ZB Bridge-P/ZB Bridge-U, SmartThings hub v3, Echo Plus 2nd…
A reliable connection is crucial for your Zigbee network.ZBMINIR2, as a Zigbee router device with Turbo Mode', supports extending up to 64 Zigbee end devices, boosts signal strength, and expands coverage for optimal performance.
Annoyed by your smart bulb going offline when the external switch is off? Try 'Detach Mode'! Keep your smart bulb connected and worry-free, even with the external switch off. Worried about damage from sudden power restoration after an outage? Delay power-on is your solution, preventing harm from high currents when multiple loads turn on simultaneously.
Based on the Zigbee 3.0 standard protocol, ZBMINIR2 seamlessly integrates with third-party open-source platforms, such as Home Assistant, Zigbee2MQT( Zigbee Dongle is required, e.g. SONOFF ZBDongle-P/ ZBDongle-E) making it perfect for your home automation needs.
Effortlessly Smartify Your Existing Switch
Upgrade your traditional external switch into a smart one, seamlessly integrating smart technology into your home for enhanced convenience and control.
Rich External Switch Types Support
Highly flexible and compatible with various external switch types, ensuring wide usage and adaptability for all your needs.
Great Solution for Using with Smart Bulb
Annoyed by your smart bulb going offline when the external switch is off? Try ‘Detach Mode’! Keep your smart bulb connected and worry-free, even with the external switch off.
Expansive Zigbee Signal Coverage
A reliable connection is crucial for your Zigbee network. ZBMINIR2, as a Zigbee router device with ‘Turbo Mode’, boosts signal strength and expands coverage for optimal performance.
Delay Power-on for Load Protection
Smart Covers Every Daily Details
Carefully attend to every detail, ensuring convenience seamlessly integrates into all aspects of your daily routine.
Ensuring Safe Use with High Quality
Compatible with Multiple Zigbee Hubs
Integration with Third-party Platforms
Based on the Zigbee 3.0 standard protocol, it seamlessly integrates with third-party open-source platforms, making it perfect for your home automation needs.
Works with Apple Home Via Matter Bridge
All solutions integrate SONOFF Zigbee devices into your Apple ecosystem via Matter Bridge, enabling seamless interconnected device control.
