ZEXEF Smart Tuya Rechargeable Switch Fingerbot Socket Bot Light Garage Curtains Robot Remoter Alexa Google Home Voice Assistant
Fingerbot is the world’s smallest robot for smartly controlling different types of plug buttons and switches. It can control your existing home appliances with robotic clicks. Switch lights via app, schedule a morning coffee, activate your vacuum cleaner with voice command, and remotely power on your office PC.
Note: please know that there is no charging cable with the switch bot
【Rechargeable】:You can charge directly through USB-C without replacing the battery, which is more energy-efficient and environmentally friendly.
【APP Remote Control】Download smart life /Tuya smart APP on your phone&Tablet to control the switch anywhere/anytime.
【Hand Free Voice Control】 Compatible with Yandex Alice amazon alexa echo ,google home ect ,a simply command to voice control the receiver.
【Timer,Schedule&Count Down Function】You can create schedule according to your personal requirement ,as well as timing and count down,smart and DIY your daily life to the maximum extend.
Other thingd you want to know about the product:
【BLE version】:You can directly connect to Fingerbot through BLE,if you want to remote control over Bluetooth range ,it needs to work with a Bluetooth gateway. we can offer you a discount if you need it
【Touch Control】 You can control it directly with your fingers.
【Group-Control Function】Multi switch in different room can set in a group ,realize group control function.
【Linkage Function】It can linkage with other switch module ,sensor and appliance in your home ,make create different scene possible,such as sleeping mode,working mode,dinner mode ,back home mode ect.
【Family Share Function】You can share the switch to your family with the limited right,create a smart home together
with your family member.
【Ultra-long battery life】:Low battery consumption, which has ultra-long battery life.
【Convenient installation】:Stick 3M glue on the bottom surface of the finger robot, paste it in the required position, open the mobile phone APP for configuration and use.
【Easy to Install】The micro switch module can be easily installed on the switch or on the wall.
Package Included:
1* Chargeable Fingerbot Plus
