Zigbee 3.0 DC12V COB LED Strip Light Super Thin 5MM Dimmable Tape High Density Flexible COB LED Tape Light Bar for Smarttings
$37.21
Emitting Color: Warm White
Color: 1M Kit
Note:
Needs work with Zigbee gateway.
Features:
1. High bright, no lighting spots, uniform lighting.
2. High luminous efficacy, save power.
3. Soft and flexible, can bent to make any shape.
4. Can be cut or jointed to different length.
5. With strong adhesive tape, easy to install.
6. CRI>90, better lighting show.
Parameters:
--Length:2/3/5M
--COB Width: 5mm
--Working Voltage: DC 12V
--Leds Quantity: 400Leds/meter
--RA (CRI): >90
--Waterproof Grade: IP25
--Luminous Flux:110lm/bead
--Watts:7.2W/M
--Light Color: 3000K(Warm White),6000K(White)
Zigbee controller features:
Mini size With the size of 62*25*12mm, the light controller is very convenient for user to use it in many situation.
You can adjust the brightness of the lights, set a timer, and control groups through the app. Can connect to a third party for voice control.
How to enter pairing mode:
1. Power on the smart controller, power on and off for 5 times, the LED light will start to flash quickly, once a second
2. Open APP, select lighting and add equipment
--Material: plastic
--Color: white
--Input voltage:DC12-24V
--Connection way: DC female to power supply, DC male connection to strip light
--Total length: 310mm
--Support system:Amazon ECHO Plus ,O*sr*am,SmartThings,ikea,Home Assistant,Zigbee2MQTT,Tuya zigbee etc
--Support mobile: Android/IOS
--Size:64*24*12(mm)
--Operating Temperature:-20-60°
Pack:
1x led light
1x led controller
1x led power
