Zigbee 3.0 Smart Vibration Sensor Detection APP Notification Real-Time Motion Shock Alarm History Record Support Zigbee2Mqtt
This Zigbee Vibration Sensor must work with Zigbee gateway(Not included)
Specification
Working voltage: DC 3V
Size:40mm x 40mm x13mm
Wireless connections: ZigBee 3.0(need to use zigbee hub)
Standby current: ≤15uA
Standby time: ≥15 months
Battery: CR2450(battery include)
Weight range: ±2g
Tilt range: ±10°
Working temperature: -10°C~50℃
Working humidity: ≤95%
【Vibration Detection Sensor】Enable the vibration detection function in the App. When the device detects vibration, the APP alarm notification function will be triggered. Really monitor your home safety.
【Tilt Detection Sensor】Enable the tilt detection function in the App. When the sensor tilts, the App alarm notification function will be triggered.
【Sensitivity Setting】You can set the sensitivity in the App according to your needs, with a wide range from low to high; support historical records to monitor your home more accurately.
【Real-time Remote Monitoring】No matter when and where, once the vibration sensor detects vibration or movement, you will receive a push notification from your smartphone in the App as real-time monitoring.
【Smart Linkage】The vibration sensor can be used in conjunction with other zigbee products to achieve smart linkage for the whole house (smart scenes need to be created)
【Support Zigbee 2mqtt ,home assistant】
