Zigbee 3.0 Water Leak Sensor Smart Leakage Detector Built-In Smart Siren 85Db Alarm Work Home Assistant for Home Security
GIRIER ZigBee Water Leak Sensor Smart Leakage Detector Built-in Smart Siren Alarm for Home Security System
ITEM DESCRIPTION
Detect Water Leakage Remotely
Assist you to monitor your home security wherever you are.
Leaking and Dripping Detection
The highly sensitive sensor effectively monitors for any water leaks or dripping, ensuring prompt detection and notification.
Alert in Real-time
With its butil-in siren, you can hear the alarm when this leakage monitor detects the leaking/dripping.
Smart Automation Scenes
Integrate this smart water leakage sensor with other smart ZigBee 3.0 devices for seamlessly home automation. For instance, close the water valve in case of kitchen sink leaks or trigger window closure when water is detected on the windowsill.
ZigBee Hub Required
ZigBee gateway is required when you pair this smart water leak sensor.
More Features
☆Batteries Included
Note
1. It is not completely waterproof. Please ensure that the area near the hole of the alarm is dry.
2. Please note that when you pair it with Home Assistant, the ZigBee hub is required for pairing.
The latest version is NOT compatible with Tuya ZigBee Gateway and Tuya APP.
In the event that any issues arise with the product following its receipt, please do not hesitate to contact our online after-sales team for assistance. Our specialists are available to provide prompt support and resolve any concerns in a professional manner.
Alert in Real-time
Detect Water Leaking Remotely
Help you keep an eye on potential water leaks when you are not at home.
The highly sensitive water leakage sensor effectively for any water leaks or drippings, enduring prompt detection and notification.
Integrate this smart water leakage sensor with other smart devices for seamlessly home automation.
Tool-free Installation
You don't need any complicated wiring or tools. Just put it to the place where you want to monitor for water leaks.
Customize Smart Scenarios
Create different scenes with all of ZigBee 3.0 smart devices.
SPECIFICATION
SPECIFICATION
Type:ZigBee Smart Water Leakage Sensor
Model: Smart Flooding Alarm
Wireless Protocol: ZigBee
Battery Type:2*AAA Batteries
Working Temperature: -10℃-55℃
Working Humidity: 0-100%
Hub Requirement: Yes
Alarm Sound: 80-85 dB
Packing List
1*Water leakage detector
2*AAA Batteries
1*User Manual
