Zigbee Door and Windows Sensor Tuya Wifi Door Open/Close Detector Smart Home Automation Wireless Magnetic Door Sensor
ZigBee Gateway Hub is Required
It is needs to connect to ZigBee gateway to achieve networking
Note: Zigbee Gateway is not included and need to buy separately
Real-time Remote Monitoring
As long as the door is detected to be open or closed, you will receive a notification by smart phone
App Notification
Detect open/close status of the door/window
Tamper Alarm
The sensor is built-in tamper switch, which provides an immediate alarm in case of illegal removal
and pushes the message to the APP
Smart Power Saving
Built-in 2*CR2032 battery, 365 days standby time
Low Power Warning
When power is low, the sensor will push messages through Tuya/Smart Life to remind you to replace battery in time
Multi Scenario Application
Achieving Smart Home Security
Scene Linkage
Zigbee Gateway+Door Sensor+Bulb
When you open the door, the light will automatically turn on
Zigbee Gateway+Door Sensor+Air-conditioning
When you close the window, the air conditioning automatically turns on
Meian Tuya Zigbee 3.0 Door and Windows Sensor
Enjoy Your Smart Life
When you leave home, it will push notification message to you when the door/window opens or closes, so you can discover the intruder in time.
When you go home, through intelligent linkage, turn on the lights or air conditioning to achieve intelligent life.
Furthermore, you could share the device to your family members, track the history of sensor activities, shared intelligence.
Easy to Install
No complicated installation tools are required. The sensor can be installed with double-sided adhesive tape in just a few steps, and download an app "Tuya" or "Smart Life" from GooglePlay or App Store to add the device to detect the status of your door/window.
Long Battery Life
Built-in 2*CR2032 battery, ≈ 5mA working current, <3uA standby current, smart power saving, up to 365 days standby time.
Low Power Warning
When power is low, the sensor will push messages through Tuya/Smart Life APP to remind you to replace battery in time.
