Zigbee Door Window Sensor Ewelink APP Smart Home Security Protection Door Open Closed Detector for Alexa Google Yandex Alice
Note: Tuya/Smart Life is not supported
Feature:
1) After connecting the eWeLink ZigBee gateway, when you leave the house, it will push notification messages to you when the doors and windows are opened, so that you can detect the intruder in time
2) Download the "eWeLink" APP from GooglePlay or App Store, and add a device to detect the status of doors and windows. Home security is always in your hands
3) [Share Control and History Tracking] You can share the device to your family and track the history of sensor activity
4) [Easy to Install] Just stick one piece to your door or window, then use double-sided tape to stick the other piece to the door or window frame, just a few steps
Material: ABS
Battery: 2*AAA battery(Not included)
Detection accuracy: <5mm
Standby time: 3 years of battery life, press 5 times a day
Standby current: ≤5uA
Wireless Mode: 2.4GHz
Protocol: eWeLink ZigBee 3.0
Instructions for use: Press and hold the reset button for more than 6s with the pin when powering on for the first time, until the front indicator light flashes and releases, the indicator light flashes, then you can enter the distribution network mode
Applicable location: door/window/cabinet, etc.
Installation location: external
Protection rate: IP20
Support system: Android/IOS
Working environment: indoor
Connection method: Zigbee connection
Voice control: support Google Assistant, Alexa, Yandex Alice and other third-party voice platforms
Compatible gateway: eWeLink Zigbee gateway
Packing list:
1* Door sensor (including back sticker)
