Zigbee Human Motion Sensor,10Ghz Mmwave Radar with Luminance Temperature Humidity Sensor for Tuya Smart Life App or Zigbee2Mqtt
*Attention :
The sensor must work with with one related zigbee gateway or Z2MQTT.
Do not support for ZHA
Do not support for alexa nor google assistant .
What is the difference between these version ?
1. for Z2M(No Lux TH): only human motion sensor function
*Only support for Zigbee2mqtt in home assistant.
2.for Z2M (Lux):
human motion sensor + illuminance detection
3.for Z2M (Lux TH):
human motion sensor + illuminance detection+ temperature and humidity detection
4.for tuya (Lux ): App can use tuya smart or smart life.
*Support for tuya zigbee gateway and Zigbee2mqtt in home assistant.
5.for tuya (Lux TH): App can use tuya smart or smart life.
Product Name : Human Motion Sensor
Battery Type:2pcs*LR03/AAA(Not included)
Wireless Protocol: Zigbee3.0
MW Frequency:10.525GHz mmwave
Detection Angle:110°±10°
Detection Distance:0.5~10meter(z axis)
Luminance Meter:0~3000Lux
Temperature Resolution :0.1°C
Humidity Resolution :1%
Temperature Measurement Accuracy:±0.3°C
Humidity Measurement Accuracy:±3%
Working Voltage: DC 3.0V
Standby Current :≤80uA
Standby Time:≥8 Months
Working Temperature:-10°C~55°C
Working Humidity : max 99%RH
*Temperature and humidty parameters,products with only temperature and humidty sensor
【Zigbee Required】:The sensor must work with with one related zigbee gateway or Z2MQTT.
【Advanced Motion Sensor】 detects human body that are moving, 110° detection angle, 0.5-10m detection distance, can achieve real-time monitoring day or night. Sensitive sensing of human movement. Adjustable sensitivity. Excellux Global store.
【Luminance/ Light Detection】: With luminance detection motion sensor ,it can detect the brightness and display the estimated lux value.
【Temperature & Humidity Detection】: With luminance detection and Temperature & Humidty function motion sensor ,app can detect your house and home real time temperature and humidity
【History Records Tracking】 You can track the history of sensor activities. Excellux Global store.
【Strong Performance & Ultra-long Standby Time】 Long transmission distance, high sensitivity, and strong network signal. Ultra-long standby time. Battery is not included .
【Intelligent linkage and enjoy the new life】: Smart Home Automation. Create Smart Scenes.It can be connected to the home assistant to link with other zigbee smart products in the home . Excellux Global store.
