Zigbee Human Motion Sensor Radar Mmwave Temperature and Humidity Sensor Security Burglar Works with Home Assistant Zigbee2Mqtt
*Attention :
The sensor must work with with Home assistant-zigbee2mqtt .
Do not support for ZHA
Do not support for alexa nor google assistant .
Do not support for tuya zigbee hub
What is the difference between them ?
2 In 1: Zigbee motion sensor with luminance detection
3 In 1 : Zigbee motion sensor with luminance detection,with temperature and humidty detection .
Product Name : Human Motion Sensor
Battery Type:2pcs*LR03/AAA(Not included)
Wireless Protocol: Zigbee3.0
MW Frequency:10.525GHz mmwave
Detection Angle:110°±10°
Detection Distance:0.5~10meter(z axis)
Luminance Meter:0~3000Lux
Temperature Resolution :0.1°C
Humidity Resolution :1%
Temperature Measurement Accuracy:±0.3°C
Humidity Measurement Accuracy:±3%
Working Voltage: DC 3.0V
Standby Current :≤80uA
Standby Time:≥8 Months
Working Temperature:-10°C~55°C
Working Humidity : max 99%RH
*Temperature and humidty parameters,products with only temperature and humidty sensor
【Zigbee Required】:The sensor must work with with zigbee2mqtt Home assistant
【Advanced Motion Sensor】 detects human body that are moving, 110° detection angle, 0.5-10m detection distance, can achieve real-time monitoring day or night. Sensitive sensing of human movement. Excellux Global store.
【Luminance/ Light Detection】: With luminance detection motion sensor ,it can detect the brightness and display the estimated lux value.
【Temperature & Humidity Detection】: With luminance detection and Temperature & Humidty function motion sensor ,app can detect your house and home real time temperature and humidity
【History Records Tracking】 You can track the history of sensor activities. Excellux Global store.
【Strong Performance & Ultra-long Standby Time】 Long transmission distance, high sensitivity, and strong network signal. Ultra-long standby time. Battery is not included .
【Intelligent linkage and enjoy the new life】: Smart Home Automation. Create Smart Scenes.It can be connected to the home assistant to link with other zigbee smart products in the home . Excellux Global store.
