Zigbee Human PIR Motion Sensor Ewelink Body Movement Smart PIR Sensor Infrared Detector Home Security Alarm Support Zbbridge Z2M
【Zigbee Bridge/Zigbee hub/Zigbee gateway Required】:The pir sensor must work with one zigbee bridge;
【Advanced Motion Sensor】PIR detects human body or animals that are moving, 120° detection angle, 5m detection distance, can achieve real-time monitoring day or night.Sensitive sensing of human/pet movement
【Emergency Alert Push Function】When there is movement detected, the alert notifications will be pushed to your phone, be aware of what's happening at home even when you're away.
【History Records Tracking】You can track the history of sensor activities.
【Strong Performance & Ultra-long Standby Time】Long transmission distance, high sensitivity, and strong network signal. Ultra-long standby time. Powered by 1pcs CR2450 batteries(included), can last for about 18 months.
【Intelligent linkage and enjoy the new life】: It can be connected to the zigbee smart gateway to link with other zigbee smart products in the home
【Support Zigbee 2mqtt / Home Assistant】
Note :If you need to connect to a third-part smart device, please ensure that your third-party device has a built-in gateway, otherwise it may not be able to be added;
Product name:ZigBee human PIR motion sensor
Networking form: ZigBee
Protocol : EWelink
Model: ZG-204ZL/ZG-204Z
Detection:120°,distance < 5M
No lightness detection
Power input: Cr2450 button battery(1.5 years,10 times per day)
working temperature:-10°C~55*C
Product size:33mm*26mm
Appearance packaging:White carton neutral packaging
Package Included:
1 * PIR Motion Sensor (Battery included);
1 * User Manual;
1 * reset needle;
1* adhesive tape ;
1* cover opening tool;
