Zigbee PIR Motion Sensor Smart Movement Detector 2-In-1 Light Sensor Supports Home Assistant for Automatic Home Security
Warm Tips
Please note that when you pair it with Home Assistant, the ZigBee hub is required for pairing.
The latest version is NOT compatible with Tuya ZigBee Gateway and Tuya APP.
In the event that any issues arise with the product following its receipt, please do not hesitate to contact our online after-sales team for assistance. Our specialists are available to provide prompt support and resolve any concerns in a professional manner.
ITEM DESCRIPTION
-Monitor Your Space Efficiently
With a precise 120-degree wide-angle detection sensor, this motion detector effectively covers large areas day or night. You can easily monitor any areas you care about.
-Safeguard Your Home
Living better, sleeping better, you can rest assured knowing GIRIER security devices always protect your home. With this smart PIR motion detection sensor, detect movement near your home and automatically activate lights or trigger the smart siren to scare away potential threats.
-Instant Alerts
Receive instant notifications on your phone if motion is detected, whether you are at home or not.
-Built-in Light Sensor
Equipped with an advanced light sensor, seamlessly adjust light luminance to manage your smart home devices. Auto-illuminate stairs at night or effortlessly open curtains in dim daylight, all with a simple setup.
-Customize Smart Scenarios
Not only light and curtain, connect the ZigBee smart PIR motion sensor to other smart devices such as sirens, cameras or other smart devices to create your smart home automation system, enhancing security and convenience.
-Flexible Power Options
Choose between battery-powered or Type-C charging for reliable operation. Enjoy up to 24 months of battery life in regular mode. (Battery is included in the parcel.)
☆☆More Features
√PIR Record free checking
√Battery Included
Note
1.Not waterproofing.
2.When using Type-C charging, the battery will stop working automatically.
120° Wide-angle Motion Detection
Monitor any Area You Care About
Notice movement near your home and turn on the lights or trigger the smart siren to scare away potential threats.
Safeguard Your Home
Instant Alerts
Enjoy Your Smart Home Automation
Equipped with an advanced light sensor, seamlessly adjust luminance value to manage your smart home devices. All with a simple setup.
Battery-powered or Type-C Powered? Both OK!
Keep the History Records Up to 7 Days Freely
Not only light and curtain, connect the ZigBee smart PIR motion sensor to other smart devices such as sirens, cameras to create your smart home automation system, enhancing your home security and convenience.
SPECIFICATION
Type: PIR Motion Detector
Light Sensor: Included
Input Power:Type-C 5V1A
Battery Type: 1*CR123A
Battery: Brand New, Included
Battery Rechargeable: NO
Maximum Detection Distance: 7m
Horizontal Detection Angle: 120°
Vertical Detection Angle: 110°
Operating Temperature Range:-10℃-60℃
Operating Humidity: ≤95%RH
WiFi Standard: IEEE 802.11b/g/n 2.4GHz Only
ZigBee Standard: IEEE 802.15.4
Mounting: Adhesive
Certification: CE, RoHS,FCC
Hub Requirement: Yes
Warm Tips
1. Don't support voice checking.
2. Please note that type-c cable is not included in package and please don't use re-chargeable battery.
3. The Type-C cable is not designed to charge the battery directly; it is a power cable meant to be connected to a power charger or USB adapter to work as a power supply for the sensor. Connecting the Type-C cable to the sensor does not impact the battery's current battery power.
4.Please note that this PIR motion detector is not waterproof.
