Zigbee Smart Home Automation Tuya Smart Temperature Humidity Sensor Real-Time App Alert Remote Control Alexa Google Assistant
Notice:
1、This device only can work along with a Zigbee Geteway. You need to connect wifi with a zigbee gateway successfully before use such zigbee T&H sensor.
2、Turn on the device and smart speaker (Amazon Alexa or Google Home speaker) , they will be connected automatically;
3、The device is also compatible with eWeLink ZigBee Gateway Hub. If TUYA Smart is not available for the device, please connect it with the eWeLink ZigBee Gateway Hub.
Bullet Points:
1、Temperature and Humidity Compensation: Added temperature compensation and smart scenes to connect to your air conditioner and humidifier to provide the most comfortable temperature and humidity for your house.
2、Real-Time Information Update: Through the Smart lives and Tuya APP, you can know the changes in temperature and humidity anytime and anywhere, and you can adjust the appropriate temperature for the house by viewing the historical records.
3、Low Battery Reminder: The low voltage monitoring reminder function is designed in the App to supply power to your room thermometer humidity sensor in real-time.
4、Wide Range of Uses: Our room thermometer humidity sensor can be used for a house, baby room, greenhouse, wine room, incubator, and humidor. It is widely used.
5、After-Sales Service: We provide high-quality products and great service. If you have any questions, you can contact us and we will provide a variety of solutions for you to choose from.
Description:
Our smart temperature humidity sensor can add temperature compensation and smart scenes, which can provide the most comfortable temperature and humidity for your house. It is suitable for a house, baby room, greenhouse, wine room, incubator, and humidor.
Specification:
Name: Wireless Temperature and Humidity Sensor
Scope of application: home, studio, school, factory
Material: ABS
Temperature measurement range: -10-55 (℃)
Humidity measurement range: 0-99 (RH)
Temperature measurement accuracy: 1 (℃)
Humidity measurement accuracy: ±5 (RH)
Temperature measurement error: 1 (℃)
Humidity measurement error: 5-8 (RH)
Use battery: 2* AAA dry battery
Packing List:
1*sensor (without battery)
1*instruction
Notes:
1. Due to the different display and lighting effects, the actual color of the product may be slightly different from the color shown in the picture.
2. Due to manual measurement, please allow a measurement deviation of 1-3cm.
