Zigbee Smart Temperature and Humidity Sensor Battery Powered Security Mini Thermometer Hygrometer with Tuya Smart Life App
Function:
1.Tuya Smart ZigBee Temperature and Humidity Sensor:A Tuya ZigBee Wireless Gateway Hub is a must to work with the temperature and humidity sensor,as well as a variety of ZigBee smart products, which is proved to be the bridge and control center for smart homes and plays an irreplaceable role for all ZigBee products and realizes the whole intelligent linkage of your house.Simply add the sensor into the ZigBee hub after adding the hub into Smart Life/Tuya App;
2.Real-time perception of temperature and humidity changes and real-time report to your smart phones with Smart Life Tuya App supported.View history record in App for smart controls for your house temperature and humidity.Monitor your house temperature and humidity no matter where you are;
3.Can be used with Alexa and Google home;
4.New ZigBee technology with low power consumption microprocessor for long standby.Designed with low voltage monitoring reminder function in App for real-time power supply for your sensor.Battery powered with long battery life;
5.New added with temperature compensation technique with smart scene linkage to your air conditioning and humidifier,offering your house with the most comfortable temperature and humidity to enjoy our smart life;
6.Widely used in various places and easily stick it to the wall with the sticker for simple installation,light and compact.Easy set up; and configure to your Smart Life App for convenient control.
Specification:
Battery model: 3V CR2032
Transfer Protocol: Zigbee
WiFi frequency: 2.4 GHz
Working voltage: 2.3V-3.3V
Working Current: Average 5mA (Zigbee)
Standby Current: <3uA
Scope of application: indoor use
Detection range: ambient temperature and humidity
Working temperature: -20 to 60℃
Relative humidity: 0 to 95% (without condensation)
Installation method: paste and fix
Transmission distance: 10-30 meters indoor and 30-50 meters outdoor (for reference only)
Note:
This product needs to be used with tuya's ZigBee gateway, and cannot directly connect to WiFi.
Please allow 1-3cm differs due to manual measurement.
Due to the different display and different light, the picture may not show the actual color of the item. Thanks for your understand.
