Zigbee Soil Moisture Sensor Temperature Humidity Meter Fertility Light Tester for Tuya Smart Life Z2M Home Assistant Automation
Regular price $15.78
Regular price $0 $15.78 Sale price
Low stock
Soil moisture sensor ,Zigbee 2mqtt and Zigbee Tuya version optional ,All require zigbee hub to pair on the app!!!,
Before You Buy: Choose the Right Protocol for Your Smart Home, The product not support ZHA-Zigbee home automation /Ewelink)
Overwatering?-----Underwatering?---------Not Enough Light?-------------Why is it not thriving? Is it the soil, the temperature, the humidity or light?
Stop guessing. Start measuring.
Welcome to our smart home family! We're excited to help you choose the right Zigbee protocol for your needs. Whether you're looking for seamless integration with Home Assistant or a smooth experience with the Smart Life Tuya app, we've got you covered.
Here's a friendly overview of the key features of our product:
1) Zigbee Hub Required: To connect with the app, you'll need a Zigbee hub. For Zigbee Tuya version, please use a Zigbee Tuya gateway for the best performance.
2) Light Sensor Option: We offer 3-in-1, 4-in-1 versions And 5-in-1 version. The 4-in-1/5-in-1 model includes a light intensity detection feature, while the 3-in-1 does not.The 5-in-1 verison included Fertility ,while the 3in1/4in1 does not .
3) App Remote Control: Stay connected to your garden from anywhere in the world. Check your soil's temperature and humidity right from your smartphone.
4) Water Shortage Warning: Our smart system will gently remind you when it's time to water your plants, helping you keep your green friends happy and healthy.
5) Smart Monitoring: Keep track of air temperature, humidity, soil moisture,light intensity, Fertility, so you always know what's happening in your garden.
6) Comprehensive Measurement Range: Our sensor accurately measures soil moisture from 0% to 100%, giving you complete insight into your plants' hydration needs.
7) User-Friendly Design: Compact, lightweight, and incredibly easy to use. Just plug it in and you're ready to go. With low power consumption, the batteries last a long time - making it the perfect companion for your garden care.
Product Specifications:
- Product Name: Soil Moisture Sensor
- Wireless Protocol: Zigbee 3.0 (requires Zigbee hub to operate)
- Soil Moisture Range: 0%-100%
- Temperature Resolution: 0.1℃
- Humidity Resolution: 1%
- Temperature Measurement Accuracy: ±0.5℃
- Humidity Measurement Accuracy: ±5%
- Battery Type: LR03AAA Battery *2pcs (not included)
- Working Voltage: DC3.0v
- Standby Current: ≤20uA
- Standby Time: ≥12 months
- Temperature Unit Conversion: ℃-℉
- Working Temperature: -10℃-55℃
- Working Humidity: Max 99% RH
Package Contents:
- Soil Moisture Tester *1 (batteries not included)
- User Manual *1
