Zigbee Tuya DC24V FCOB RGB LED Strip Light FOB Flexible COB Linear Lights Dimmable Home Decor Tuya Zigbee APP for Alexa Google
$104.96
Emitting Color: 5M Full Kit
zigbee Controller Parameters:
zigbee devices require related gateways.
like ECHO Plus ,O*sr*am,SmartThings, Home Assistant , Zigbee2MQTT,tuya zigbee etc
Product Description
This new generation of RGB controller works with the ZigBee ZLL standard and is therefore compatible with many common ZigBee hubs/gateways,
With this controller all common types of LED products operating on 5-24V Volt basis can be controlled. This makes it suitable for LED strips, LED mounting beams, LED outdoor or pool lighting.
Sync your lights with movies ,music, and games,Enjoy the lighting effect which synchronizes with the plot of the picture immediately,and experience the more delicate atmosphere lighting effect.
Voice control, Smartphone APP control.
High quality LEDs: super bright COB RGB LED,long life span (in excess of 50,000 hours). Low power consumption and environmental friendly..
Wide application: can be used for decorating your home such as dining room, bed room, upstairs, kitchen, porch, desk and living rooms, especially great for holidays and events like Christmas, Halloween, Parties.
LED Controller
Voltage: DC5V-24V
Output: Max. 2A/Channel, Total output Max.5A
Product Name:Dual Port ZIGBEE Strip Controller
Operating Temperature:-20-60
APP/Voice Controller
Adjust color temperature and brightness
Note:
1.The minimum bending diameter of the LED strip is 60 mm. This avoids direct or indirect damage to the components on the FPC and FPC, resulting in an abnormality in the led strip.
2. Double-sided tape for LED strips, with its superior glue and weatherability, can be attached to any transparent glass, metal and plastic surface, but some surfaces, such as cloth and wood, can affect their function and durability. Please test the adhesion of the light bar before installation.
3.This product requires an anti-corrosion environment. For example, avoid moisture, dripping or other adverse factors.
RGB Led Specification:
Strip Length: 5M/10M
Light Color: RGB Super bright RA>90 high intensity and reliability.
Long life span 50,000 hoursFlexible ribbon for curving around bendsCompletely smooth and even light spread,
solving the uneven luminous problemUltra-bright but running at low temperatureLow power consumption
Size: L500cm (5M) x W1cm x T0.21cm
Working Voltage: DC 24V
Lighting Color : RGB
width:10mm
power:15W/M
Lumen:8-10LM
Package included
1 x Led Strip(10m=2x 5m,20M=2*10M)
1 x zigbee Control
1 x Power Adapter
Product Description
LED Controller
Voltage: DC5V-24V
Note:
width:10mm
power:15W/M
Lumen:8-10LM
Package included
1 x zigbee Control
1 x Power Adapter
