Zigbee Water Leak Detector Smart Home Overflow Security Alarm Flood Leakage Sensor Work with Homekit via ZMHK-01
Feature:
- A water leak sensor that detects water leakage in the environment in real time. When water immersion is detected, the detector sends an alarm signal to the host computer and reports the information to the user's mobile phone.
- IP67 Waterproof: Adopt integral structure waterproof design,convenient and quick installation
- Power by battery: CR2032 battery, Low voltage, Low power consumption microprocessor,long standby.
- Smart Water Leakage New smart home device for water leakage detection.When water leakage to buttom for the sensor, it will sent alarm notification to Zigbee gateway
- Remote Control on APP via Zigbee Set scene on APP, and then when have water leakage, it will push alarm notification.
- Wide Application. This water leakage detector wrok well in house, hotel, shop, office, and apartment. to protect every moment and everywhere.
Communication Mode: zigbee
Dimension:50X50X18mm
Operating Temperature: -10 to +55℃
Supply Voltage: DC3V(CR2032 battery)
Installation: Flat
Parameter Characteristics: IP67 waterproof level
Note:
The Zigbee water leak detector can not work standalone without gateway.This product is only applicable to Tuya Zigbee Gateway or ZMHK-01 Hub.
