Zigbee Wifi Smart Rotary Light Dimmer Switch Smart Life/Tuya Wireless Remote Control Brightness Memory Work with Alexa Google EU
WiFi ZigBee Smart Rotary Light Dimmer Switch Brightness Memory Smart Life/Tuya App Wireless Remote Control Work with Alexa Google Home Voice Control EU/UK switch Neutral Line Required Family Sharing Timer Schedule
Main Features:
1. New designed with rotary operations to dim your light with adjustable supported;
Brightness memory function when power off to smart your life in another concept;
Compatible with various dimmable bulbs as 200W LED,CFL, 300W INC.
2. The ZigBee version dimmer switch must work with tuya zigbee gateway hub.
Simply add the sensor into the ZigBee hub after adding the hub into Smart Life / Tuya App.
3. Non-interference control mode, allowing the switch to be controlled via Smart Life APP, touch control and voice control;
Each control method works independently, achieving multi-control by associating to other smart switches.
Compatible with Alexa and Google Home for voice control with 0%-100% dimmable.
Wireless remote control by Smart Life/Tuya app anytime, anywhere.
4. Take full control of connected appliances with automatic timers, schedules and countdown (1/5/30 mins, 1 hour, etc.) with the app.
Share control with other family members or friends for adding convenience.
Tailor your lighting to fade on with a click of the Alexa dimmer switch for keeping your eyes from strong light.
5. Neutral wire is required in your switch boxes to operate correctly, it only supports 2.4 GHz network.
Input power : 100-240V AC 50-60Hz
Dimming control : TRIAC Edge Cut
Inductive load(LED/CFL) : 220W Max
Resistive load(Incandescent) : 300W Max
Communication : ZigBee protocol/ 2.4GHz
Control channel : 1 CH
Standby power : ≤0.5W
Working temperature : -10℃-45℃
Working humidity : <90%
Button life : 50K times
Knob life : 50K circles
Dimension : 86*86*53.5mm
Enjoy Smart Life
Convert your home's lighting system to smart lighting
Device Share
Timer Schedule
Voice Control
APP Control
Hands-free Voice Control
It could work with Alexa Google Home for voice control by easy voice comments
Smart Phone APP Control
Work with Tuya/ Smart Life App for wireless remote control, control the home lighting whenever wherever you are
ZigBee Smart Rotary Dimmer Switch
Our Tuya Zigbee hub is featured as much more compatibility with our tuya devices than other hubs, and the zigbee version must work with zigbee hub.
In addition, the tuya zigbee hub is not included in the package
Adjust the Brightness According to Your Needs
Dimming the light from 0%-100% as you like
Wireless Remote Control via Tuya Smart Life
Remote control by Tuya Smart Life app, set the mood with the app from anywhere
Create Automated Schedules
Set the light to automatically turn on or off
Compatible Bulbs
CFL Dimmable 220W
LED Dimmable 220W
INC 300W
Family Share
Support to share the device to family members or friends adding the convenience
Rotary Dimming Control
Rotate your finger left and right to adjust the brightness
Installation
1. Disconnect power circuit breaker
2. Check the Line with voltage tester pen, make sure the power is off to prevent electric shock.
3. Follow the wiring instructions , connect the dimmer wires to each other leads and check for short circuits
4. Screw the dimmer into the back box
5. Mounting switch cover plate
6. Connect circuit breaker restore power
Exquisite craft and Extraordinary Protection Mechanism
Safe . Efficiency . Environmental
Dimension
