57946 B-hyve Smart Indoor/Outdoor 6-Station WiFi Sprinkler System Controller, Compatible with Alexa
Regular price $302.21
Regular price $302.21 Sale price
Shop B-hyve WiFi Sprinkler System Controller
The b-hyve Smart Indoor/Outdoor 6-Station WiFi Sprinkler System Controller brings intelligent irrigation management to your garden. This advanced controller adapts to local weather forecasts, watering only when necessary to conserve water and reduce costs. With remote access through the app, you can manage your irrigation system anytime, from anywhere. Its sleek, durable design withstands both indoor and outdoor environments, ensuring reliable performance
Transform your garden's watering routine with the b-hyve sprinkler controller, designed to make irrigation simple and efficient. This WiFi Sprinkler System Controller connects directly to your home WiFi, allowing you to control up to six zones through a smartphone app or voice commands with Alexa. The b-hyve smart watering system leverages local weather data to automatically adjust your watering schedule, ensuring plants receive optimal hydration based on real-time conditions.
  • Smart Scheduling: Set custom schedules for each zone, adapting to seasonal changes with ease.
  • Weather Awareness: Avoid overwatering by syncing with local weather forecasts, automatically delaying watering during rain.
  • Easy App Control: Manage all zones remotely, making adjustments and monitoring usage from any location.
  • Alexa Compatibility: Enjoy hands-free control through voice commands, integrating seamlessly with your smart home setup.
Usage & Benefits
Using the b-hyve sprinkler controller simplifies lawn care, reducing water waste and ensuring healthy plants. With this WiFi Sprinkler System Controller, you get total flexibility for lawn maintenance without the hassle of manual control. The b-hyve smart watering feature also promotes eco-friendly gardening practices, making it ideal for sustainable water management. Whether you're home or away, this controller keeps your landscape green and lush with minimal effort.
B-hyve rain delay
Wi-fi timer
B-hyve app
b-hyve zones
Adjusts to Local Weather
Smart watering sets automatic delays for rain, wind and freezing temperatures, even when running a traditional program, saving you water and money.
B-hyve can automatically check your local weather conditions many times each day, recalculate the soil moisture level in each zone, and then make smart choices about when and how long to water.
Rebate Eligible
B-hyve complies with EPA WaterSense weather-based irrigation controller protocols, which qualifies it for a rebate from water agencies and cities in many locales. See the B-hyve rebate center for eligibility.
To locate the B-hyve rebate center, simply search in your browser for "B-hyve rebate center" and enter your zip code.
WeatherSense Technology
Your B-hyve looks ahead at the weather forecast, shuts off water during rain, then recalculates your watering schedule.
In the event of rain, high wind, or freeze, B-hyve automatically delays watering until normal conditions return and then recalculates the appropriate watering schedule, helping you take advantage of beneficial rainfall and saving water.
Custom Schedules and Zones
Take pictures and name each of your zones on the B-hyve app.
Allows for up to four custom watering schedules tailored to diverse types of zones in the landscape. Includes multiple start times which allows creation of cycle and soak windows to encourage water infiltration into your soil.
Manual run feature on app and at device allows you to run one zone, select zones or programs, or all zones for a specified length of time, which is very convenient for zone testing or supplemental watering even when you might not have your smartphone handy.
b-hyve
B-hyve
Orbit Sprinkler Timer
B-hyve
Outdoor Weather-Proof Locking Cabinet
B-hyve comes equipped with a weather-proof locking door and two keys, allowing you to mount your timer indoors or outdoors for no additional cost. The display is mounted on a swing panel which allows you to easily access wiring.
Control From Anywhere: Wi-Fi Enabled
With the B-hyve app you can control your sprinklers from anywhere in the world from your smart device. Giving you peace of mind that your landscape will be taken care of no matter where you are.
Monitor your watering history data logs by day, month, year, and check year-over-year comparisons on the B-hyve app.
You can also control the timer when you are at home via Bluetooth, regardless of whether you have Wi-Fi at the location or a Wi-Fi router near the timer.
LCD Display and Control Buttons
If needed, you can fully control your B-hyve timer with it's physical buttons and LCD display.
Easily set manual watering's, or even create full watering programs at the timer itself.
Easy Installation
B-hyve is engineered for easy installation in an indoor or outdoor location. Installation is as simple as mounting the timer on the wall, putting the common wire (typically white wire) in the C terminal and the individual zone wires in each of the numbered station terminals, plugging in the power cord, and setting the schedules.
The recommended standard sprinkler wire for this timer is 18-guage thickness with 5 or 7 strands/wires.
Hose Timers
Irrigation Controllers
Hose Sprinklers
Nozzles & Wands
Sprinkler Systems
Drip Watering
Outdoor Mist Cooling
