Aeotec Z-Wave Plus Z-Stick 7
Regular price $51.60
Regular price $51.60 Sale price
Shop Aeotec Z-Stick 7 USB Stick at Affordable Price
The Aeotec Z-Wave Plus Z-Stick 7 is a powerful and reliable USB adapter that allows you to control your smart home devices from your computer or laptop. With Aeotec's advanced Z-Wave Plus technology, it provides fast and secure communication with your devices, ensuring that your commands are executed quickly and reliably.
The Aeotec Z-Wave Plus Z-Stick 7 is compatible with a wide range of Z-Wave devices, including lights, thermostats, locks, and sensors. It can also be used with popular home automation software such as Home Assistant and OpenHAB.
Its compact and portable design makes it easy to use at home or on the go, and its plug-and-play setup means you can start controlling your devices in minutes. Whether you're a home automation enthusiast or a professional installer, the Aeotec Z-Wave Plus Z-Stick 7 is an essential tool for building a smarter, more connected home. The Aeotec Z-Stick 7 USB stick's compact and portable design makes it perfect for use at home or on the go. Its plug-and-play setup ensures you'll be controlling your smart home devices in minutes. Some of the key features of these Z-stick 7 by Aeotec are:
  • Z-Wave Plus technology
  • Wide compatibility
  • Compact and portable
  • Plug-and-play setup
Take the first step towards a smarter home with the Aeotec Z-Stick 7 USB stick. Experience the power and convenience of Z-Wave technology now and shop at affordable price.
Manufacturer Part #: ZWA010
UPC: 810667025250
Z-Wave Chip: ZGM130, 700 series
Frequency: 908.42MHz
Security: S2 native QR Code
Inclusion: SmartStart native
Known compatibilities: Tested to be compatible with Raspberry Pi 3 and up
Tested to be compatible with Windows 10 OS
Tested to be compatible with Linux OS
Tested to be compatible with OSX OS
CPU speed: 39 MHz
SRAM Memory: 32 kB
Flash Memory: 256 kB
Power Supply: USB DC 4.75V to 5.25V
Standby current: 18 - 20 mA
Max current: 40mA
Recommended host current: 50mA
Operating Temperature: 40 to 104 degrees F (0 to 50 degrees C)
Storage Temperature: -4 to 158 degrees F (-20 to 70 degrees C)
Operating Distance: Up to 492 feet (150 meters) outdoors in normal mode or 230 feet (70 meters) indoors
Dimensions: 37 x 17 x 8.5 mm
1.46 x 1.1 x 0.33 Inch
Certifications: Z-Wave Plus, FCC, CE, RoHS
Warranty: 1 Year
