Detects leaks before they become expensive disasters
Complete Protection for Your Smart Home or Office: Prevent water damage before it happens with the Ezlo Z-Wave Flood Sensor. From burst pipes to low pool levels, get instant alerts on leaks and floods.
  • Superior Range: Built on the latest Z-Wave 800 series for faster, more reliable connectivity.
  • 3-in-1 Monitoring: Equipped with temperature and vibration sensors to detect threats beyond just water.
  • Always On: Ultra-low power consumption ensures continuous, long-term protection.
  • Versatile Use: Perfect for detecting burst pipes, leaking overflow units, or diminishing water levels in pools and tanks.
Stop Leaks Proactively with Ezlo Water Valves
Maximize your peace of mind by linking your sensor to the Ezlo Water Valve. Seamless integration allows the sensor to automatically trigger the valve to close, stopping disasters in their tracks even when you aren’t home.
Advanced Flood Protection with Z-Wave 800
Detects floods, leaks, and low water levels with Z-Wave 800 technology.
Flexible Water Detection
The sensor can be used with its built-in prongs for direct floor placement or utilize the extension probe to reach remote or difficult-to-access areas, ensuring comprehensive coverage.
Persistent Performance, Superior Battery Longevity
Ultra-low power Z-Wave technology ensures years of reliable, uninterrupted performance.
App and Ecosystem Integration
  • MiOS App: Control and monitor your sensor remotely through the MiOS app, available for iOS and Android devices.
  • Home Assistant Ready: Works with Home Assistant, enabling deep-dive automations.
  • Latest Z-Wave Protocol: Utilizes the Z-Wave 800 series for advanced, long-range connectivity.
  • US-Based Customer Care: Enjoy peace of mind with US-based, real-person customer support ready to assist you whenever you need help.
  • Advanced Automation: Seamlessly integrate with MiOS and EzloPi for complex automation routines.
  • Home Assistant Ready: Works perfectly for simple use or deep-dive automations within Home Assistant and other smart home environments.
  • Voice Activation: Compatible with Amazon Alexa and Google Assistant, allowing for hands-free control of associated devices.
  • Ultra-Low Power: Designed for long-lasting battery life with a low battery alert.
Power Supply:
ER14250 3.6V Battery
Radio protocol:
Z-Wave Plus
Z-Wave Radio frequency (US):
908.42MHz (standard), 912.00MHz (default LR), 920.00MHz (backup LR)
Range:
More than 300 feet outdoor, about 130 feet indoors (depending on materials)
Operational Temperature:
32~104°F
Dimensions:
Main body: 68 mm(W)*22mm(H),
Extension probe: 50 mm(W)*5mm(H),
Wire: 1000mm(L)
Ezlo
Ezlo Z-Wave Flood Sensor 2 Pack
Regular price $44.00
Regular price $55.00 $44.00 Sale price
Stop water damage before it starts. The Ezlo Flood Sensor provides 24/7 peace of mind by detecting leaks, burst pipes, and shifting water levels instantly. Built on the cutting-edge Z-Wave 800 series, it offers industry-leading range and reliability. More than just a leak detector, this 2-in-1 device also monitors temperature, ensuring your property is protected from every angle with ultra-low power consumption for long-term security.
IMPORTANT USAGE NOTE
Battery & Probe Information
Power Source: This device requires a single ER14250 3.6V Battery. Thanks to ultra-low power consumption, it is designed for long-lasting operation.
Probe Placement: The sensor includes a 1000mm (3.2 ft) wire probe. Place the probe tip where water is most likely to accumulate (e.g., under a sink) or at the desired water line (for tanks/pools).
Frequently Asked Questions
Q: Do I need a hub to use this sensor?
A: Yes. This is a Z-Wave 800 Series device. It requires a Z-Wave compatible hub (such as an Ezlo controller or other Z-Wave gateways) to send alerts to your phone and trigger automations.
Q: What exactly does it detect?
A: It features Dual Detection Capability. It can detect sudden water presence (leaks and floods) to prevent damage, but it can also detect critically low water levels, making it perfect for monitoring pools or water tanks.
Q: Does it monitor anything besides water?
A: Yes. It provides Integrated Monitoring with two additional sensors: a Temperature Sensor (to detect freezing conditions before pipes burst) and a Vibration Sensor (to detect tampering or equipment shaking).
Q: How far is the wireless range?
A: It utilizes the latest Z-Wave 800 Series protocol. This provides long-range connectivity, capable of reaching more than 300 ft outdoors and approximately 130 ft indoors, ensuring reliable alerts even from basements or garages.
Q: Can it trigger other devices automatically?
A: Yes. You can set up Automated Schedules and scenes. For example, if a leak is detected, the sensor can automatically trigger a smart water valve to shut off the main water line or sound a siren to alert you immediately.
Q: Does it work with Home Assistant?
A: Yes. The sensor is "Home Assistant Ready." It integrates seamlessly for users who want to create complex automation rules within the Home Assistant ecosystem.
A: If you need help with placement or pairing, we are here to assist. Please contact our customer care team at 866-966-2272 or email us at support@ezlo.com.
