Matter Smart Switch Matter Wall Switch Matter Light Switch Touch Wall Light Neutral Wire/No Neutral Wire 1/2/3/4 Gang
Regular price $44.74
Regular price $0 $44.74 Sale price
Matter WiFi Smart Wall light Switch Neutral NO Neutral Wire 1/3Gang LED with touch sensor Smart Life Work with Alexa Google Home
Description:
Shell: PC Flame Retardant Material
Installation Method: Zero Fire Wire/single Zero Fire Universal
Working Voltage: 100V-240V
1. Support Third-party Voice Control: Apple Homekit Alexa,Gogle Voice Smart Audio Control
2. Timing Setting: APP Setting Timing Control, Remote Setting On And Off
3. Support: Power-off Memory
Package Included:
smart siwtch: Metter-White-1/2/3Gang
Connection Protocol:
Utilizing the Matter protocol, this smart plug seamlessly connects to your home network via WiFi, ensuring reliable and robust communication.
Support:
With built-in WiFi connectivity, this smart plug effortlessly connects to your home network, enabling remote control and automation via compatible smart speaker.Natively Wi-Fi-enabled and also compatible with Thread networks.
Matter wall switches can coexist with Zigbee and Bluetooth devices in the same smart home ecosystem, as long as those devices also support the
Matter protocol or are bridged through a Matter-enabled gateway.
Operating Voltage: Designed to operate within a wide voltage range of AC100~240V, this smart plug is compatible with most electrical systems worldwide.
Platform Support: Say goodbye to third-party platforms. This smart plug offers direct integration with popular smart speaker apps such as HomeKit, Echo, Google Home, and SmartThings. Simply scan the QR code, and you're ready to go.
Dimensions: Compact yet powerful, measuring at 120*72*34mm, this smart plug fits discreetly into any standard power outlet without obstructing neighboring sockets.
Advantages of the Matter protocol:
Unified standards: The Matter protocol provides a common language that allows smart home devices from different manufacturers to communicate with each other, breaking down previous ecosystem barriers.
Cross-platform compatibility: Supports multiple mainstream smart home platforms, and users are no longer limited to the limitations of a single ecosystem.
Simplified device management: Users can manage all Matter devices through any Matter-enabled control center without installing multiple applications.
Security and privacy protection: Enhanced security measures ensure the security and privacy of user data.
Compatibility with eWeLink and Tuya
Matter wall switches can ensure interoperability between all devices through the Matter protocol even when eWeLink or Tuya devices are also present
The introduction of the Matter protocol means that future smart home devices will focus more on openness and interoperability, reduce dependence on specific platforms, and give consumers greater flexibility and freedom when choosing devices.
Maximum Power: Each outlet boasts a maximum power handling capability of 1000W per gang, empowering users to control a wide range of electrical devices effortlessly.
Power Loss Memory Functionality: Never worry about losing your preferred settings during a power outage. The button-controlled power loss memory function ensures that the smart plug remembers its state, providing uninterrupted convenience.
