Smart Life Tuya Garage Door Opener Wifi or Zigbee Wireless Control RF433 Timer Schedule Alexa Google Assistant Compatible
Regular price $29.80
Regular price $0 $29.80 Sale price
This product is a WiFi/Zigbee smart switch that supports controlling your garage door opener and monitoring the door's status at any time. You can add your device to the APP to control your garage door remotely.
Notes:
A Zigbee garage door switch must require a Zigbee gateway.
WiFi garage door switch must work in 2.4G WiFi environment and does not support 5G WIFI.
Specification:
Power supply: DC 5V
Wireless standard: IEEE802.11b/g/n
Wireless type: 2.4GHz only, does not support 5G
Mobile phone: Tuya Smart/Smart life
Voice control: Alexa / Google Assistant / Yandex Alice
Installation method: screw/sticker
Line length: 5M
Material: ABS+PC
Working temperature: -10℃~50℃
Item size: approx. 6.1*4.5*2.2cm (length*width*height)
Item Weight: Approx. 150g
Packaging size: approx. 88*38*22mm
Feature:
【Remote Open/Close】Turn your existing WiFi network and garage door opener into an integrated smart device, then you can open and close your garage door with just a click of your smartphone.
【Timing Schedule】You can set schedules and timers to open and close the garage door. Manage your garage door with ease.
[Voice Control] It can realize voice control of Amazon Alexa/Echo, Google Home/Yandex Alice, which is very convenient.
[Device Sharing] You can share it with your family, friends or visitors. Of course, you can withdraw permission at any time.
【History】You can check the garage door switch history on the APP to ensure the safety of the garage.
Easy installation:
Power the device using a DC 5V/500mA adapter and micro USB cable.
Connect the red and black wires to the garage door opener: Connect each end to the same terminal where the wall button wire terminates.
Connect the sensor and install it firmly on the garage door with screws/3M adhesive/brackets, etc.
Control devices on your smartphone.
