Smart Tuya Zigbee Led Strip Light Wifi USB TV Led Backlight Tape RGB Lights Works with Alexa /Zigbee Hub/Google /Smartthings
Regular price $9.38
Regular price $9.38 Sale price
Shop Smart Tuya Zigbee LED Strip USB Powered, Voice-Controlled RGB Lighting
Enhance your entertainment experience with the Smart Tuya Zigbee LED Strip Light—a versatile and intelligent lighting solution designed to bring vibrant illumination to your living spaces. This RGB LED Strip for TV is engineered to provide dynamic backlighting, creating an immersive atmosphere whether you're watching movies, gaming, or simply relaxing.​
  • Smart Connectivity: Seamlessly integrates with Zigbee hubs, allowing for effortless control through popular platforms like Alexa, Google Assistant, and SmartThings. This enables voice-activated commands and automation, enhancing convenience.​
  • Versatile Installation: With its flexible design and USB LED Tape Light configuration, this strip can be easily attached to various surfaces, making it ideal for TV backlighting, computer monitors, or accentuating room features.​
  • Vibrant Lighting Options: Featuring RGB LEDs, the strip offers a wide spectrum of colors and adjustable brightness levels, allowing you to customize the ambiance to suit any mood or occasion.
  • Energy Efficient: Operating at a low voltage of 5V DC and consuming minimal power, this LED strip ensures energy savings without compromising on brightness or color quality.​
  • Enhanced Viewing Experience: Installing the WiFi LED Backlight behind your TV or monitor reduces eye strain and provides a more immersive viewing experience by extending the visual impact beyond the screen.​
  • Mood Lighting: Easily adjust the lighting to create the perfect ambiance for parties, romantic evenings, or casual gatherings, transforming any space with dynamic color displays.​
  • Smart Home Integration: Compatibility with major smart home systems allows you to incorporate the LED strip into your existing automation routines, such as syncing lights with music or setting schedules for automatic operation.​
Installation Tips
  1. Preparation: Ensure the surface where the LED strip will be installed is clean and dry for optimal adhesion.​
  2. Placement: Measure and cut the strip to the desired length, if necessary, following the manufacturer's guidelines to avoid damaging the circuitry.​
  3. Connection: Connect the USB plug to a power source, such as a TV USB port or a wall adapter, ensuring it matches the strip's voltage requirements.​
  4. Integration: Pair the LED strip with your Zigbee hub and configure it using the associated app to access smart features and voice control.​
By incorporating the Smart Tuya Zigbee LED Strip Light into your home, you not only elevate the aesthetic appeal of your space but also enjoy the convenience and versatility of smart lighting solutions.
Regular price $9.38
