Tuya Smart Home Zigbee Door Sensor Alarm Window Door Open/Closed Detectors Security Protection Smart Life for Alexa Google
$7.21
Color: Zigbee 1Pc
Notes: If you choose the ZigBee version, it needs a ZigBee escape of Yours for it to work.
【One-key 2.4GHz WiFi connection Easy setup】
No need home gateway, you can easily achieve the smart control of household appliances, simple operation, easy to use. The 2.4G Hz protocol is more stable, faster and convenient
【Detect the status of the door/window】
When the door/window is opened or closed, the device is activated and sends a notification to the phone.
【Alarm linked with more sensors】
Set the scene: out-of-home mode, if someone breaks in, the device is activated and sends a notification to the phone., AND THE IP CAMERA (not included) will record the video. When someone opens the door, the light turns on automatically.
【Remote control app】
Home is in your hands, whenever and wherever
【Easy to install】
Small size, easy to install Adhesive installation, can be flexibly placed on various doors, windows, drawers, etc., without destroying the appearance and structure of the original furniture
Input voltage: 3V LR03
Quiescent current: ≤ 45uA
Alarm current: ≤ 130mA
Low voltage: ≤ 2.4 V
Wifi: 802.11 b/g/n
Magnetic control distance: >10mm
Battery: DC 3V LR03 (AAA battery, not included)
Alarm mode: Mobile phone app Push notification (Smart Life/Tuya Smart)
Size: Main body: 68*23*19mm
Permanent magnet: 43*10*14mm
Package included:
1 * sensor
1 * manual
1 * sticker
