Tuya Zigbee 3.0 Temperature Humidity Sensor Smart Home Indoor Hygrometer App Remote Monitor Work with Smart Life Z2M Need Hub
Regular price $27.22
Regular price $0 $27.22 Sale price
Tuya Zigbee 3.0 Temperature Humidity Sensor Smart Home Indoor Hygrometer App Remote Monitor work with Smart Life Z2M Need Hub
1. This device only can work along with a Zigbee Geteway. You need to connect wifi with a Tuya zigbee gateway successfully before use such zigbee sensor.
2. The device is also compatible with eWeLink ZigBee Gateway Hub.
Specification
Wireless Protocol: Zigbee 3.0(need to use zigbee hub)
Temperature Measurement Accuracy: ±3℃
Humidity Measurement Accuracy: ±5%RH
Working Temperature: -20℃~60℃
Working Humidity: 0%~100%RH
Temperature Resolution: 1℃(decimal point not displayed in the Tuya app, displayed in the Z2M)
Humidity Resolution: 1%(decimal point not displayed in the Tuya app, displayed in the Z2M)
Working Voltage: DC 3.0V
Standby Current: ≤20uA
Battery Type: 2 x LR03 AAA(not included)
App: Tuya Smart/Smart Life(cannot work via wifi directly); Home Assistant Z2M(zigbee2mqtt) not ZHA(zigbee home automation)
Package Content
1* Zigbee Temperature&Humidity Sensor
1* User Manual
1* Paper Clip
1* Double-sided Sticker
Tuya Smart ZigBee Temperature and Humidity Sensor: A Tuya ZigBee Wireless Gateway Hub is a must to work with the temperature and humidity sensor,as well as a variety of ZigBee smart products, which is proved to be the bridge and control center for smart homes and plays an irreplaceable role for all ZigBee products and realizes the whole intelligent linkage of your house.Simply add the sensor into the ZigBee hub after adding the hub into Smart Life/Tuya App;
Real-time perception of temperature and humidity changes and real-time report to your smart phones with Smart Life Tuya App supported.View history record in App for smart controls for your house temperature and humidity.Monitor your house temperature and humidity no matter where you are;
New ZigBee technology with low power consumption microprocessor for long standby.Designed with low voltage monitoring reminder function in App for real-time power supply for your sensor.Battery powered with long battery life;
New added with temperature compensation technique with smart scene linkage to your air conditioning and humidifier,offering your house with the most comfortable temperature and humidity to enjoy our smart life.
