Tuya Zigbee Smart Light Sensor Luminance Sensor APP Control Brightness Sensor Illumination Brightness Detector
Tuya Zigbee Smart Light Sensor Illumination Brightness Detector APP Control Home Lighting Automation Smart Home Light Detector
Feature:
1. Real-Time Light Sensing: The smart light sensor provides precise real-time monitoring of illumination levels, helping you effortlessly optimize the lighting conditions in your environment. Perfect for ensuring the right amount of light at all times.
2. Dynamic Light Curve Visualization: The luminance sensor features an interactive curve that tracks and analyzes changes in light over time. This intuitive visualization allows you to see how light levels fluctuate throughout the day.
3. Smart Automation: The brightness sensor integrates seamlessly with your smart home setup, enabling endless possibilities. Set different smart scenes to trigger based on light changes, automating your devices intelligently.
4. Easy Installation: The illumination brightness detector boasts a versatile design that can be easily adhered to any surface, enhancing your smart living experience without hassle. Enjoy seamless integration into your home.
5. Long Battery Life: The smart home light detector operates on a CR2032 button battery, providing a year of worry-free use. It also comes with a low battery alert to ensure you are never left in the dark.
Specification:
Origin: Mainland China
Communication method: zigbee
Low battery warning: Yes
Operating temperature: -10℃~+50℃
Battery specification: CR2032 (included in the delivery)
Detection range: 0~1000Lux
Product size: 50x17mm/1.97x0.67inch
Packaging size: 55*55*25mm
Gross weight: 29g
Note: It needs to be used with Zigbee gateway!
Feature:
Specification:
Gross weight: 29g
Note:
1 X Light Sensor
1 X Instruction Manual
1 X Reset Pin
1 X 3m Sticker
1 X Reset Pin
1 X 3m Sticker
