Tuya Zigbee Water Leak Detector Water Flood Sensor Smart Life App Alert Overflow Water Leakage Sensor for Kitchen/Bathroom
  • Intelligent Leak Detection: The ZigBee Flood Sensor instantly detects leaks and triggers alerts via the Smart Life or Tuya Smart app, keeping you informed wherever you..
  • Stable ZigBee Connectivity: Designed for seamless integration with your smart home ecosystem, ensuring a strong and reliable connection
  • Ideal for Multiple Locations: Whether you need a bathroom flood alarm or a kitchen water leak sensor, this compact device is perfect for placement near sinks, applianc..
  • Long-Lasting Battery: Operates on a low-power CR2032 battery with over a year of battery life, reducing the need for frequent replacements
  • Compact and Durable: Water-resistant design ensures durability, making it ideal for humid environments and discreet placement
Shop Tuya ZigBee Water Leak Detector – Instant Alerts & Smart Protection
Protect your home from costly water damage with the Tuya ZigBee Water Leak Detector, a reliable solution for detecting leaks before they escalate. This smart ZigBee Flood Sensor provides instant notifications, helping you take immediate action to prevent flooding in vulnerable areas like kitchens, bathrooms, and basements.
  • Intelligent Leak Detection: The ZigBee Flood Sensor instantly detects leaks and triggers alerts via the Smart Life or Tuya Smart app, keeping you informed wherever you are.
  • Stable ZigBee Connectivity: Designed for seamless integration with your smart home ecosystem, ensuring a strong and reliable connection.
  • Ideal for Multiple Locations: Whether you need a bathroom flood alarm or a kitchen water leak sensor, this compact device is perfect for placement near sinks, appliances, and pipes.
  • Long-Lasting Battery: Operates on a low-power CR2032 battery with over a year of battery life, reducing the need for frequent replacements.
  • Compact and Durable: Water-resistant design ensures durability, making it ideal for humid environments and discreet placement.
  • Smart Home Compatible: Works with Alexa, Google Home, and other ZigBee hubs for voice alerts and automation.
  • Prevent Costly Water Damage: Detect leaks early to help protect your floors, walls, and valuables.
  • Peace of Mind Anywhere: Get real-time alerts on your phone, whether you're at home or traveling.
  • Easy Installation: No wiring is required. Simply place the ZigBee Flood Sensor where leaks are most likely to occur.
