Tuya ZigBee Water Sensor Leakage Alarm Flood Leak Detector Smart Home APP Remote Control Smart Home Security Protection
Hign-concerned Chemical: None
Model Number: SJ-01
Origin: Mainland China
Certification: CE,RoHS
Smart home platform: Alexa,Tuya,Google Assistant
- Hign-concerned Chemical: None
- Model Number: SJ-01
- Origin: Mainland China
- Certification: CE,RoHS
- Smart home platform: Alexa,Tuya,Google Assistant
Note: All Zigbee products require a Zigbee gateway or a multi-mode gateway
Power input: AAA battery(included)
Battery working life: more than one year, 10 times a day (replaceable)
Material: ABS
App name: Smart Life/TUYA
Description:
【Real-time detection】
A water immersion sensor that can detect water leakage in the environment in real time. When water immersion is detected, the detector will send an alarm signal to the host and report the information to the user's mobile phone. When the water level at the detection point reaches 0.5mm, the water intrusion sensor will report the water condition.
【Scene linkage】
The preset security scene is realized through the mobile APP. Once the monitored water level reaches the preset height, the alarm will be raised remotely. When the early warning water level is reached, the linkage gateway will send out a local sound and light alarm, and the mobile phone will receive the APP push reminder to let you know in time, and the mobile phone can close the water outlet by the remote electromagnetic valve.
【Long battery life】
The battery can supply power for 1 year (if the reminder is 10 times a day)
【Multi-scene application】
The water leak detector can work normally in houses, hotels, shops, offices and apartments. Protect every moment.
Package Included:
1 *zigbee water sensor
1 *manual
