Tuya ZigBee WiFi Smart Dimmer Switch Module Supports Two Way Control Breaker Works with Alexa Alice Google Home, Need Neutral
  • Dual-Protocol Support: Operates on both Zigbee and WiFi networks, ensuring broad compatibility with various smart home systems
  • Two-Way Control: Allows control of your lights from multiple locations within your home, enhancing convenience
  • Voice Assistant Integration: Compatible with Alexa, Google Home, and Alice, enabling hands-free operation
  • Scheduling and Automation: Set timers, schedules, and countdowns to automate your lighting based on your daily routines
  • Group Control: Manage multiple dimmer switches simultaneously by grouping them, providing synchronized lighting control
The Tuya Zigbee WiFi Smart Dimmer Switch Module is a versatile device that enables seamless control over your home's lighting system. Designed to work with both Zigbee and WiFi protocols, it offers flexibility and compatibility with various smart home ecosystems. This module supports two-way control, allowing you to manage your lights from multiple locations within your home. Additionally, it integrates with voice assistants like Alexa, Google Home, and Alice, providing hands-free operation for added convenience. Please note that this module requires a neutral wire for installation.
The WiFi Dimmer Module is engineered to provide precise control over your lighting, allowing you to adjust brightness levels to suit your preferences. Its dual-protocol support ensures compatibility with a wide range of smart home systems, enhancing its versatility. The WiFi Dimmer Switch Module is designed for easy installation, fitting into standard switch boxes or lamp boxes, making it a convenient upgrade for your existing lighting setup.
  • Dual-Protocol Support: Operates on both Zigbee and WiFi networks, ensuring broad compatibility with various smart home systems.
  • Two-Way Control: Allows control of your lights from multiple locations within your home, enhancing convenience.
  • Voice Assistant Integration: Compatible with Alexa, Google Home, and Alice, enabling hands-free operation.
  • Scheduling and Automation: Set timers, schedules, and countdowns to automate your lighting based on your daily routines.
  • Group Control: Manage multiple dimmer switches simultaneously by grouping them, providing synchronized lighting control.
  • Neutral Wire Requirement: Requires a neutral wire for installation, ensuring safe and reliable operation.
To install the Smart Dimmer Switch Module, connect it to your existing lighting circuit, ensuring a neutral wire is available. Once installed, pair the module with your smart home hub or app to configure settings, create schedules, and integrate with voice assistants for hands-free control.
  • Enhanced Lighting Control: Adjust brightness levels to create the perfect ambiance for any occasion.
  • Energy Efficiency: Optimize lighting usage to reduce energy consumption and lower electricity bills.
  • Convenience: Control your lights remotely via smartphone apps or voice commands, adding convenience to your daily life.
  • Smart Home Integration: Seamlessly integrates with other smart home devices, allowing for comprehensive automation and control.
Upgrade your lighting system with the WiFi Dimmer Switch Module to experience enhanced control, convenience, and energy efficiency in your smart home.
