Wifi Smart Light Switch 2 Way Control Module AC 110V 220V Voice Control Ewelink APP Work with Alexa Google Home Alice
  • Mini Design: The compact smart switch module (dimensions: 4.1 x 4.1 x 2.0 cm) is designed to fit seamlessly into standard wall switch boxes for hidden installation, pr..
  • The mini switch module supports a maximum current of 16A and can be paired with multiple 2.4GHz panel switches, enabling remote control of lights on the upper floors f..
  • Mini Design: The compact smart switch module (dimensions: 4.1 x 4.1 x 2.0 cm) is designed to fit seamlessly into standard wall switch boxes for hidden installation, preserving the original aesthetics. It supports a wide input/output voltage range of AC 100V–240V, ensuring compatibility with global power systems.
  • The mini switch module supports a maximum current of 16A and can be paired with multiple 2.4GHz panel switches, enabling remote control of lights on the upper floors from the ground floor. Users can monitor the device’s real-time status via the app at any time.Note:It only supports 2.4GHz frequency networks.
  • App Control: No separate hub is required – simply remotely control the device via the free EweLink app, which supports multiple functions, including voice-controlled on/off, scene creation, countdown timers, and scheduling.
Bi-directional switch: The mini smart switch module can be used as a single-way or two-way switch (i.e., 2 switches to control 1 light). Simply connect it to one of the two-way switches to turn the connected switch into a smart switch.
