Zigbee Temperature and Humidity Sensor with LED Screen Display CR2032 Battery Compatiable with Alexa Google Assistant Smart Life
Need to work with Tuya gateway
The default update cycle is 30 minutes If the temperature change is greater than 0.5 degrees Celsius or the humidity change is greater than 5%, the data is uploaded to the phone in real time.
Product parameter
Input voltage: DC3V CR2032
Static current: s20uA
Working current: s15mA
Low voltage: s2.5V
Zigbee: lEEE 802.15.4
Detection temperature:-9.9*C~+60°C
Detection humidity: 0-99%RH
Installation mode: Wall mount/Place desk
Set button:
Press the set button shortly to switch
the temperature to Fahrenheit, and
hold the reset button for 3 seconds to
enter the configuration state
Product parameter
Low voltage: s2.5V
Set button:
