Tuya Zigbee Vibration Sensor Real Time Monitoring Door Window Detection Alarm Smart Home Security Protection System
Notes: If you choose ZigBee Product, you need a Tuya ZigBee getaway to make it work.
Specification:
Working voltage: DC 3V
Standby current: ≤ 10uA
Alarm current: ≤ 20mA
Wireless type: ZigBee 3.0
Transmission distance: 10-30 meters
Installation method: 3M tape
Battery: 1.5V AAA dry battery * 2(not included)
Working temperature: -10 ℃~50 ℃
Working humidity: ≤ 95% (no condensation)
Vibration Alarm
When the sensor falls or detects vibration, it will send an alarm notification to your smartphone, allowing you to immediately check the situation at home and ensure its safety
Smart Linkage
It can be linked with other Tuya intelligent products. For example, linkage with smart curtain switch: when the sensor detects vibration, open the curtains
Real-time Remote Monitoring
No matter when and where, once the vibration sensor detects vibration or movement, you will receive a push notification from your smartphone in the Tuya Smart Life App as real-time monitoring.
Sensitivity Setting
You can set the sensitivity in the App according to your needs, with a wide range from low to high; support historical records to monitor your home more accurately.
View History Records
Support recording the historical data of sensor operation, you can view the sensor's past work records on the mobile app
Sharing Function
You can share the sensor with your family and friends, so they can also check the working status of the sensor like you do
Package Included:
1x Vibration Sensor
1x Sticker
1x User manual
